My 800
Started by Darth Wraith, September 09, 2013, 03:41:58 AM
Darth Wraith
Probably some sort of advanced 4D visual technology from outer space...
testpilot
I took my glasses off and they cleared up. Nice photos, Greenbarn.
Time flies like an arrow. Fruit flies like a banana.
mittico68
Hey guys, does anybody know a good eye doctor? My eyes just see blurry pics! ;D
I love my swingin' bike!
   :P Think Chief should hire you to the staff as the forum photo guy....your amazing....
Quote from: CDNRatMan on October 15, 2013, 18:55:08 PM
very nice pictures hey Mr. 0hi0 sure makes you wish you could take photos too eh!
Hey,I can take pictures.  Actually I'm quite talented here are some special ones just for you ratman...
You will find:
1) Pic from the bike show.  I think this was a Drifer, but he was going so fast, the fenders look smaller.
2) some scenery from vacation.
3) the biker chick at the beach in her red-white-blue biker bikini
4) a recent wedding where I was the guest photographer
5) finally, a bachelor's party, with some hot dancers.
Disclaimer/ copyright notice:  these are not really my intellectual property, but shared from the internet...
Darth Wraith
No, all VN800 have that feature, and EN500, too.
Meanwhile, autumn in Romania:
The hardest learned lessons are the longest remembered....
Just curious, is the Drifter the only vulcan w/ this security feature??   From what I read when researching model numbers, the Drifter was considered the "top of the line" vulcan when it came out.  There was the plain-old-ordinary-old Vulcan, then the Classic was an upgrade, and the Drifter was the Premium.  I would agree with that... ;D
It's not all that well known now. The tech at the dealer, who's quite knowledgeable, hadn't heard of it before, but he won't forget it..and neither will I..
So the resistor is actually in the ig switch, and sends a reduced voltage to the ECM?  So if you were to try to "hot wire" the bike, by jumping the ignition switch, it still wouldn't run b/c it wouldn't see the fuel pump enable signal, from this resistor?   Of course if they were all built w/ 100ohms, I guess the thief can just wire that in.  'Course, this probably wasn't all that well known back when they were new, I suppose....
  I had (have, but now all it does is control my amp) one of those thunder ign switches on mine, installed by the P.O. I was starting to have some intermittent no start problems back in '10 after a long ride. No fuel pump until it cooled off. Turned out it was the ign switch wiring. There is one pin on the EFI computer that shows no connection in all the wiring diagrams. That pin gets a specific voltage signal from the switch. If it doesn't see the signal, or an incorrect value, then it won't turn on the fuel pump. This is rather expensive information...I bought a fuel pump, thinking that was the problem...it wasn't. The dealer called Kawasaki inquiring about the problem. They thought it was the EFI computer...Kaw. told them about the anti theft device built into the switch and EFI computer. I now have a factory stock ign. switch, and no more issues. There have been quite a few of the '99s with this failure, so if the pump won't run, that's the first thing to investigate...
The 1500's have theft protection?  I did not know that- never heard of it... tell me about it.   100 ohm resistor?   starting to sound like the 90's GM products, with a resistor chip built in the key.   GM had something like 15 or 18 different resistor values built into the key, and the BCM has to see the right value to disable the anti-theft.  The antennae ring built into the key cylinder always goes bad, or the really-really fine wire going up the steering column starts to break, and it causes what start out as intermittent no-starts, soon to turn into permanent no-starts....
Do you need the resistor in the circuit for an 800? I'm thinking no. The resistor goes to the EFI computer so the system's built in theft protection won't kick in.
Darth Wraith
It's working. This is the link - but I guess it's easier for you to buy such a thing from your country - http://www.moto-gear.ro/contact-pornire-cu-cheie-36-72-big-twin-produs-157236.html
If you want to do it, make sure that you insert an 100ohm resistor on the ignition wire.
mittico68
I guess I'm going to make a 2 cents question, but here I go: does the new ignition switch work, or is it just a fake switch?
Darth Wraith
The original switch and the idiot lights are now in the spare parts box...  :) I am not sure where is the best place for the idiot lights, I could put them on the headlight in a classic style, but I'm still thinking and open to suggestion...
That's pretty cool, I like it.
So where did you put your idiot lights that were there where the switch is now?  Did you leave the original key switch under the tank, or delete it?
Darth Wraith
It's a all metal vintage replica of a HD classic switch, I guess it's easy to find on ebay, not expensive. I made the plate and modified a little the switch to attach it to the tacho house using two screws ( I got to change the tacho light, so I will take a picture for you then) and then the electric stuff...
mittico68
Cool Drifter. I like the 2tone paint.
Btw, where did you find the ignition switch? I know there is a link on this Forum, but it leads to nothing at all :(
Darth Wraith
Darth Wraith
  COOL thanks, I don't have a drifter to use as a ref. but I am working on a few ideas here. They look just like the ones I bought, could not find them in black, and because they are plastic powder coating them is out of the question, so plastic rattle can it will be.
kw-retrorider
