The Cherohala Skyway—North Carolina’s $100 Million Mountain Road
Started by Feed Poster, May 20, 2026, 12:21:04 PM
The Cherohala Skyway—North Carolina's $100 Million Mountain Road
Stretching 51 miles between Robbinsville, North Carolina, and Tellico Plains, Tennessee, the Cherohala Skyway is often referred to as the most expensive road ever constructed in North Carolina. By the time the final pavement was laid in 1996, the project had consumed more than three decades of planning and construction and cost well over $100 million.
And when you ride it, you understand exactly where that money went.
The Cherohala Skyway doesn't simply cross the mountains – it threads through them with remarkable precision. Massive cuts were carved into steep Appalachian ridges. Countless engineering challenges had to be overcome to build a modern scenic highway across terrain that was remote, rugged, and environmentally sensitive. Construction began in 1960, but the final link wasn't completed until 36 years later, making the Skyway one of the longest-running highway projects in the region.
The Cherohala Skyway has many pull-offs and overlooks, so be sure to stop and enjoy the view.
The name itself combines the two national forests it traverses: Cherokee in Tennessee and Nantahala in North Carolina. Chero-hala. Together, those forests form a corridor of uninterrupted mountain wilderness where the Skyway rises above 5,300 feet and delivers some of the most expansive views in the Southeast.
For motorcyclists, the result feels less like a state highway and more like a purpose-built riding experience. Unlike older mountain roads that evolved from wagon routes or river valleys, the Cherohala Skyway was engineered for flow. The corners are broad and sweeping. Elevation changes are dramatic but smooth. Sight lines are generous. The pavement feels sculpted into the terrain specifically for momentum and rhythm.
That's what separates it from nearby roads like the Tail of the Dragon. U.S. Route 129 attacks the mountains aggressively with nonstop technical corners and constant intensity. The Cherohala, by comparison, breathes. Riders settle into long arcs and elevation transitions that unfold gradually across the ridgelines. It's a road that rewards pacing rather than aggression.
Bald River Falls is located near Tellico Plains and is a short ride off of the Cherohala Skyway.
The Tennessee side begins gently outside Tellico Plains, easing riders into the mountains through dense hardwood forest and river valleys before beginning the steady climb toward the high country. As elevation builds, temperatures often drop noticeably, especially in spring and fall.
Then the scenery opens. Mountain overlooks begin appearing one after another, revealing layered Appalachian ridges stretching deep into the horizon. On cooler mornings, fog can settle beneath the roadway, creating the sensation that the Skyway is floating above the valleys below.
It's easy to understand why riders return here repeatedly. The road surface remains exceptionally well maintained, and the sweepers encourage smooth riding rather than abrupt braking or rapid transitions. Traffic is typically lighter and more relaxed than the region's more famous motorcycle roads, which adds to the experience.
Bald River Falls is one of the few true ride-by waterfalls in Southern Appalachia, where riders can experience the roar of cascading water just feet from the road as it spills dramatically into the Tellico River gorge.
Descending toward Robbinsville, the road tightens slightly as the North Carolina mountains begin to close in around the route. Suddenly, the Skyway reconnects riders to the broader Appalachian riding network – Moonshiner 28, the Tail of the Dragon, and countless forest roads spiderwebbing through the Smokies.
But even among those legendary names, the Cherohala stands apart because of its scale. Few roads in the Southeast feel this elevated, this expansive, or this intentionally designed around the riding experience itself. The Cherohala Skyway may have cost more than $100 million to construct, but what riders receive in return are uninterrupted mountain vistas, flowing pavement, and one of the most complete high-country motorcycle rides in America.
That and $100 million views.
Travel Resources
Click here to view the route on REVERClick here to download the GPS file
At a Glance
Location: Eastern Tennessee and Western North CarolinaDistance: Approximately 51 milesRide Time: 1.5-3 hours (not including overlooks and stops)Best Direction to Ride: Eastbound or westboundSkill Level: Beginner to IntermediateBest Bike Type: Sport-touring, touring, ADV, standard, sportbike
Road Conditions
The Cherohala Skyway is fully paved and exceptionally well maintained, with smooth asphalt and broad, flowing curves that encourage consistent rhythm riding. Unlike many older Appalachian roads, the Skyway was engineered specifically as a scenic mountain highway, resulting in generous sight lines and gradual transitions between corners.
The route climbs above 5,300 feet, bringing substantial elevation changes and cooler temperatures. Weather can shift rapidly at altitude, especially during spring and fall. Fog is common during early mornings, and wet pavement or scattered debris may appear after storms. Wildlife crossings, including deer and black bears, are possible throughout the corridor.
Traffic is generally lighter and less chaotic than nearby U.S. 129, though weekends and peak fall foliage season bring increased motorcycle and tourist activity. Fuel and services are unavailable on the Skyway itself, so riders should plan accordingly before entering the route.
Best Time to Travel
Late spring through fall is the prime riding season for the Cherohala Skyway. May and June bring cool mountain air, lush forests, and relatively light traffic, while October transforms the route into one of the Southeast's premier fall-color rides.
Summer temperatures remain pleasant at elevation, though afternoon thunderstorms are common in the mountains. Winter can bring snow, ice, and temporary closures, particularly along the highest sections of the road. Riders should always verify weather and road conditions before departure during colder months.
Weekdays offer the most relaxed experience, especially during autumn tourism season when the region becomes extremely popular. Early mornings provide the clearest air and lightest traffic but may also bring dense valley fog and colder temperatures. Layered riding gear is strongly recommended year-round due to rapid elevation-related temperature swings.
Road Food
Both ends of the Cherohala Skyway are well adapted to motorcycle tourism. Tellico Plains offers several rider-friendly diners and cafés serving classic Southern breakfasts, barbecue, burgers, and comfort food before heading into the mountains.
On the North Carolina side, Robbinsville has become a major basecamp for riders exploring the Smokies. Local restaurants cater heavily to motorcycle traffic, and it's common to see parking lots filled with touring bikes and sportbikes throughout the riding season.
Nearby Deals Gap also offers classic rider-stop culture with food and souvenirs. Services along the Skyway itself are nonexistent, so riders should fuel up and carry water before riding the route.
Here are a few of our favorite places to eat:
Tellico Beach Drive-InA classic roadside burger stand and longtime local favorite known for milkshakes, hot dogs, and laid-back small-town atmosphere just minutes from the Cherohala Skyway.
Tellico Grains BakeryPopular with riders for its fresh-baked bread, pastries, pizzas, and cafe-style breakfasts served inside a restored historic building downtown.
Iron Works GrilleA rider favorite along the Tellico River offering burgers, Southern comfort food, and outdoor seating that makes an ideal post-Skyway stop.
TellicafeA classic Southern diner near the western entrance of the Cherohala Skyway known for generous portions, hearty breakfasts, and motorcycle-friendly parking.
Tapoco TavernOne of the Smokies' most iconic motorcycle stops, featuring riverside dining, mountain scenery, and easy access to both the Cherohala Skyway and Tail of the Dragon.
Lynn's PlaceA small-town diner known for hearty Southern breakfasts and comfort food that has become a staple stop for riders exploring western North Carolina.
Nearby Lodging
Robbinsville and Tellico Plains both offer excellent lodging options for riders using the Cherohala Skyway as part of a larger Appalachian motorcycle trip. Small motels, rider-focused lodges, cabins, campgrounds, and rental homes are common throughout the region.
Robbinsville serves as one of the primary motorcycle hubs in western North Carolina thanks to its proximity to the Tail of the Dragon, Moonshiner 28, and the Cherohala itself. Many accommodations offer trailer parking, covered motorcycle parking, and group-friendly layouts.
Camping is widely available throughout the Cherokee and Nantahala national forests for riders seeking a more immersive mountain experience. Reservations are highly recommended during peak foliage season and major motorcycle event weekends, when the region fills quickly.
Here are a few of our favorite places to stay:
Cherohala Mountain Trails CampgroundPopular with ADV and touring riders thanks to its tent camping, cabins, rider-friendly atmosphere, and close proximity to the Skyway. Frequently used as a basecamp for multiday Smoky Mountain riding trips.
129 CabinsA motorcycle-friendly cabin option near the Smoky Mountains in Robbinsville, North Carolina, offering a laid-back basecamp right along the legendary US 129 riding corridor.
Cherohala Skyway CabinsQuiet mountain cabins near Tellico Plains featuring covered motorcycle parking, hot tubs, and direct access to the Cherohala riding corridor.
The Lodge at TellicoA rider-owned lodge designed specifically for motorcyclists, complete with secure bike parking, wash stations, group gathering spaces, and quick access to the Cherohala and Tail of the Dragon.
Iron Horse Motorcycle LodgeOne of the Southeast's best-known motorcycle lodges, offering cabins, camping, meals, and a rider-focused atmosphere near Robbinsville and the Tail of the Dragon.
Dragon’s Rest CabinsMotorcycle-friendly mountain cabins near Robbinsville catering specifically to riders exploring the Cherohala Skyway, Moonshiner 28, and U.S. 129.
Blue Boar InnA quiet mountain inn near Robbinsville that serves as a comfortable basecamp for exploring western North Carolina's famous motorcycle roads.
Snowbird Mountain LodgeA historic, all-inclusive mountain lodge overlooking Lake Santeetlah and the Nantahala National Forest, offering rustic cabins, fine dining, and a quiet, upscale retreat just outside Robbinsville that's perfect for riders looking to unwind after a day on the Cherohala Skyway.
Points of Interest
Cherokee National Forest
Tail of the Dragon (U.S. 129)
North Carolina Highway 28 (Moonshiner 28)
The Foothills Parkway
Bald River Falls
Santeetlah Lake
Joyce Kilmer Memorial Forest
Scenic mountain overlooks along the Skyway
Deals Gap motorcycle resort area
If You Have More Time
The Cherohala Skyway works best as part of a larger Southern Appalachian riding loop. Riders can easily combine it with the Tail of the Dragon, Moonshiner 28, the Blue Ridge Parkway, and countless lesser-known mountain connectors across Tennessee and North Carolina.
For riders seeking more technical pavement, nearby State Route 28 offers tighter corners and denser forest riding. Those looking for scenic cruising can continue eastward toward the Blue Ridge Parkway for long-distance ridge riding through the Smokies.
This entire region rewards exploration beyond the marquee roads. Some of the best riding experiences come from wandering the unnamed forest highways and mountain backroads connecting the major routes together.
The post The Cherohala Skyway—North Carolina’s $100 Million Mountain Road appeared first on Rider Magazine.
Source: The Cherohala Skyway—North Carolina's $100 Million Mountain Road
