New and Cool Motorcycle Gear: January 2026
Started by Feed Poster, January 06, 2026, 22:01:05 PM
Keep up with the latest in motorcycling gear, parts, accessories, and products with Rider's New and Cool Motorcycle Gear monthly installments. The items in this list are available now.
Spectro V-Twin Oil Change Kits
New and Cool Motorcycle Gear January 2026 Spectro V-Twin Oil Change Kit
Spectro's new V-Twin Oil Change Kits, which hit the market in January 2026, are designed to make motorcycle maintenance easier. Available for Harley-Davidson and other V-Twin motorcycles, the kits include everything needed to change your oil in one complete package, eliminating the need to shop for individual items. The kits include engine, transmission, and primary oils, as well as a high-quality oil filter and all necessary drain-plug O-rings. Visit the Spectro website to find more information, shop the full lineup of motorcycle products, and locate a dealer near you.
Yuasa Powersports Batteries
New and Cool Motorcycle Gear January 2026 Yuasa Batteries GYZ Series
Yuasa, the leading supplier of OEM batteries for many motorcycle manufacturers, offers high-performance Absorbent Glass Mat batteries that are ideal for powersports applications. The GYZ series is a good choice for heavy touring bikes and offers a high CCA (cold cranking amps) rating, high amp hours, and built-in brass nuts for conductivity. The YTZ series is a lightweight option ideal for sportbikes and offers vibration and corrosion resistance, as well as an expanded grid design for safety and reliability. View these and other options at the Yuasa website.
Butler Maps Blue Ridge Parkway Map
New and Cool Motorcycle Gear January 2026 Butler Maps Blue Ridge Parkway Map
The Blue Ridge Parkway, running 469 uninterrupted miles through the Appalachian Mountains, is a must-ride for any motorcyclist and offers some of the best views anywhere. The Butler Maps Blue Ridge Parkway map offers all the info needed to make the most of a visit to the BRP. It includes ratings of each segment based on wow factor, ride quality, and scenery, as well as must-see attractions, scenic pull-offs, historic sites, campgrounds, and more. The waterproof and tear-resistant map is available for $21.95. Visit the website for Butler Maps' full range of maps.
Triumph Youth Electric Dirtbikes
New and Cool Motorcycle Gear January 2026 Triumph TXP-12 and TXP-16 Youth Electric Dirtbikes
Inspiring the next generation of riders are the Triumph TXP-12 and TXP-16 electric dirtbikes. Both bikes offer a 2-in-1 design to switch between a trials bike and a seated off-road bike, and they include a magnetic safety lanyard, two-stage startup, and a PIN-protected control panel. The TXP-12 is for ages 3-5 and is powered by a 600-watt, 43-volt brushless motor with a 14-mph top speed. The TXP-16 is for ages 5-7 and includes upgraded components and a 765-watt, 43-volt motor with a top speed of 19 mph. The TXP-12 is available for $1,695, and the TXP-16 is $2,295.
The post New and Cool Motorcycle Gear: January 2026 appeared first on Rider Magazine.
Source: New and Cool Motorcycle Gear: January 2026
