2026 Kawasaki KLE500 ABS Preview 
Started by Feed Poster, November 05, 2025, 22:00:28 PM
2026 Kawasaki KLE500 SE ABS
2026 Kawasaki KLE500 SE ABS in Pearl Blizzard White
New for 2026 is the Kawasaki KLE500 ABS, available in a standard trim and an SE version. This accessible and affordable adventure bike features rally-inspired styling and off-road-ready specs, and it slots between the Versys-X 300 and KLR650 in Kawasaki's adventure lineup.
It's powered by the liquid-cooled 451cc parallel-Twin also found in Kawasaki's Eliminator, Ninja 500, and Z500 models. Full specs for the KLE 500 have not been released yet, but the Z500 makes 51.0 hp at 10,000 rpm and 31.7 lb-ft at 7,500 rpm. Its 6-speed transmission includes a slip/assist clutch, and it has a steel trellis frame that uses the engine as a stressed member. Suspension includes a KYB nonadjustable 43mm inverted fork and a new Uni-Trak rear shock with stepless spring preload adjustability. Wheel travel is 8.3 inches in front and 7.9 inches in the rear, and ground clearance is 6.8 inches.
Brakes include a 2-piston front caliper with a 300mm disc and a 2-piston rear caliper with a 230mm disc. Nissin-supplied ABS can be disabled via a switch on the left side of the handlebar, and ABS resets to active when the bike is switched off and restarted.
2026 Kawasaki KLE500 ABS in Metallic Carbon Gray/Ebony
The KLE500 ABS has 21-inch front and 17-inch rear wheels with aluminum rims and steel spokes, and they're wrapped in IRC GP-410 tires. It features a wide aluminum handlebar and a slightly forward footpeg position with removable rubber footpeg inserts. Seat height is 33.8 inches, and the slim fuel tank holds 4.2 gallons. Curb weight has not yet been announced.
The KLE500 ABS comes with a standard skidplate.
Instrumentation includes an LCD instrument panel that connects to a smartphone via Rideology the App. Through the app, riders can access vehicle information and log their routes and performance data in the Riding Log function. The LCD screen also displays phone notifications, and the Economical Riding Indicator flashes to let riders know when fuel consumption is favorable.
The KLE500 ABS includes an LCD screen with smartphone connectivity.
Standard equipment includes an aluminum skidplate and an adjustable windscreen with three height levels: standard, 1.1 inches higher, and 2.2 inches higher.
The SE version gets an upgraded TFT instrument panel in place of the standard’s LCD unit.
The SE (special edition) version comes with a taller windscreen, a larger skidplate, metal-reinforced handguards, LED turnsignals (LED headlight and taillight are standard), and a 4.3-inch color TFT display.
The triple headlight is LED.
Kawasaki accessories for the KLE500 include a top case, panniers, a larger windscreen, handguards, heated grips, a USB-C port, an engine guard, a centerstand, and more.
The 2026 Kawasaki KLE500 ABS will be available in Metallic Carbon Gray/Ebony for $6,599. The KLE500 SE ABS will be available in Pearl Blizzard White or Metallic Bluish Green for $7,499.
2026 Kawasaki KLE500 SE ABS in Metallic Bluish Green
Visit the Kawasaki website for more information.
Check out more new bikes in Rider's 2026 Motorcycle Buyers Guide
The post 2026 Kawasaki KLE500 ABS Preview   appeared first on Rider Magazine.
Source: 2026 Kawasaki KLE500 ABS Preview 
