2025 Can-Am Pulse and Origin Video Review
Started by Feed Poster, November 22, 2024, 22:04:27 PM
2025 Can-Am Pulse Origin Review
Can-Am re-enters the motorcycle scene for the first time since 1987 in a bold move with two new electric bikes: the Can-Am Origin dual-sport and Can-Am Pulse roadster. Both are powered by a 11-kW Rotax E-Power motor with an 8.9-kWh battery, producing a claimed 47 hp and 53 lb-ft of torque. Interesting features include liquid cooling to extend battery life, the enclosed chain case that reduces maintenance and sound, and the 10.25-inch TFT touchscreen display with Apple CarPlay.
Curious to find out how these electric motorcycles perform, we accepted Can-Am's invitation to Austin, Texas, where we put the Pulse and Origin through their paces, flicking the Pulse through tight city streets and ripping the Origin around a 400-acre off-road ranch. Although all electric bikes today suffer from limited range, we were impressed by the bikes' build quality, performance, design, and tech.
Read our 2025 Can-Am Pulse and Origin Review
2025 Can-Am Pulse / Origin Specs
ENGINE
  • Type: Liquid-cooled Rotax E-power electric motor
  • Power: 47 hp peak, 27 hp continuous
  • Torque: 53 lb-ft from 0 to 4,600 rpm
  • Maximum Speed: 80 mph
  • Claimed Range: 80 miles (combined), 100 miles (city) / 71 mi. (combined), 90 mi. (city)
  • Battery: Lithium-ion 8.9 kWh
  • Charging Type: On-board charger, 6.6 kW (Level 1 & Level 2 compatible)
  • Charge Time, Level 1: 5 hr. 15 min. (0–100%), 3 hr. 10 min. (20–80%)
  • Level 2: 1 hr. 30 min. (0–100%), 50 min. (20–80%)
  • Transmission: Single speed
  • Final Drive: Enclosed chain
CHASSIS
  • Wheelbase: 55.6 in. / 59.0 in.
  • Rake/Trail: 27.2 degrees/4.0 in. / 30.0 degrees/4.6 in.
  • Seat Height: 30.9 in. / 34.0 in.
  • Ground Clearance: 5.7 in. / 10.2 in.
  • Suspension, Front: 41mm fork, no adj., 5.5 in. travel / 43mm fork, no adj., 10.0 in. travel
  • Rear: Single shock, adj. spring preload, 5.5 in. travel / Single shock, fully adj., 10.0 in. travel
  • Brakes, Front: Single 320mm disc w/ 2-piston floating caliper & ABS
  • Rear: Single 240mm disc w/ 1-piston floating caliper & ABS
  • Wheels, Front: Cast aluminum, 17 x 3.50 in. / Spoked, tube-type, 21 x 1.85 in.
  • Rear: Cast aluminum, 17 x 4.50 in. / Spoked, tube-type; 18 x 2.50 in.
  • Tires, Front: 110/70-17 / 90/90-21
  • Rear: 150/60-17 / 120/80-18
  • Curb Weight: 390 lb / 412 lb (factory claim)
GEAR UP
The post 2025 Can-Am Pulse and Origin Video Review appeared first on Rider Magazine.
Source: 2025 Can-Am Pulse and Origin Video Review
