2024 Honda Shadow Aero
Started by Feed Poster, August 03, 2024, 10:15:10 AM
2024 Honda Shadow Aero.
2024 Honda Shadow Aero. (Honda/)
Honda's Shadow Aero is a classically styled metric cruiser with a fully modern powertrain. For 2024 it received a disc brake at the rear, which was previously only available on the ABS version. Buyers will still have to choose between the non-ABS or ABS model (California buyers can only buy the ABS version). The two-tone paint is also new for 2024.
Power comes from a liquid-cooled 745cc V-twin that produces good low-down torque. Programmed Fuel Injection ensures excellent response and efficacy. The Aero uses a five-speed transmission and sends power to a low-maintenance shaft
final drive.
An ultralow 26-inch seat means a wide range of riders can get their feet firmly down at stops or maneuvering in parking lots.
The 2024 Honda Shadow Aero is available in one color, which Honda calls black but is really a two-tone fade on the tank and side covers. The non-ABS version is set at $7,949, while the ABS model is $8,249.
  • <a href="https://www.cycleworld.com/story/buyers-guide/2020-yamaha-bolt-r-spec/"><b>Yamaha Bolt R Spec, $8,899</b></a>
  • <b>2025 </b><a href="https://www.cycleworld.com/story/buyers-guide/2020-suzuki-boulevard-c50t/"><b>Suzuki Boulevard C50, $9,299</b></a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/2020-kawasaki-vulcan-900-classic-lt/"><b>Kawasaki Vulcan 900 Classic, starting at $9,399</b></a>
2024 Honda Shadow Aero / Shadow Aero ABS Claimed Specs
MSRP:$7,949 / $8,249 (ABS)
Engine:SOHC, liquid-cooled V-twin; 3 valves/cyl.
Displacement:745cc
Bore x Stroke:79.0 x 76.0mm
Compression Ratio:9.6:1
Transmission/Final Drive:5-speed/shaft
Fuel System:PGM-FI w/ 34mm throttle body
Clutch:Wet, multiplate
Frame:Steel
Front Suspension:41mm telescopic fork; 5.5 in. travel
Rear Suspension:Dual shocks, preload adjustable; 3.6 in. travel
Front Brake:2-piston caliper, 296mm disc (w/ ABS)
Rear Brake:1-piston caliper, 276mm disc (w/ ABS)
Wheels, Front/Rear:Spoked; 17 in./15 in.
Tires, Front/Rear:120/90-17 / 160/80-15
Rake/Trail:34.0ยบ/6.3 in.
Wheelbase:64.6 in.
Ground Clearance:5.1 in.
Seat Height:26.0 in.
Fuel Capacity:3.9 gal.
Wet Weight:560 lb. / 570 lb. (ABS)
Contact:powersports.honda.com
Source: 2024 Honda Shadow Aero
Motorcycle Cruiser
