2024 Honda NX500
Started by Feed Poster, July 27, 2024, 22:14:31 PM
2024 Honda NX500
2024 Honda NX500.
2024 Honda NX500. (Honda/)
As far back as the late 1980s, the letters "NX" have represented adventure, meaning New X-over (crossover). For 2024, Honda has renamed the CB500X and changed it to NX500. But the bike gets a lot more than just a name change. Overall weight is down by 7 pounds, dropping from 439 to 432, while the new cast-aluminum wheels have saved 3.3 pounds of unsprung weight alone. Other additions include standard Honda Selectable Torque Control, ECU updates for improved acceleration, new suspension settings, a new 5-inch TFT display, and new LED headlight.
At its core is a liquid-cooled 471cc
parallel-twin engine that has been tuned for low- to midrange torque between 3,000 and 7,000 rpm. The engine is fed by PGM-FI fuel injection and as mentioned now comes standard with Honda's Selectable Torque Control (traction control).
Chassis highlights include the suspension that utilizes a 41mm Showa Separate Function Fork Big Piston (SFF-BP) fork with 5.2 inches of travel, and preload-adjustable Showa shock with 5.3 inches of travel. Wheelbase measures 56.8 inches, while the seat height has been kept at a reasonable 32.8 inches. A pair of Nissin two-piston calipers and 296mm discs and a single-piston caliper and 240mm disc take care of braking, and ABS is standard. The new lighter cast-aluminum wheels have Y-shaped spokes and are mounted with 110/80-19 front and 160/60-17 rear rubber.
2024 Honda NX500.
2024 Honda NX500 Pricing and Variants
The 2024 Honda NX500 is available in Matte Black Metallic for $7,399.
2024 Honda NX500 in Matte Black Metallic.
2024 Honda NX500 in Matte Black Metallic. (Honda/)
  • <a href="https://www.cycleworld.com/story/buyers-guide/triumph-tiger-sport-660-2022/">Triumph Tiger 660 Sport, $9,695<br/>
    </a>
  • <a href="https://www.cycleworld.com/motorcycle-reviews/yamaha-tenere-700-first-ride-review/">Yamaha Ténéré 700, $10,799<br/>
    </a>
  • <a href="https://www.cycleworld.com/motorcycle-reviews/kawasaki-klr650-s-first-ride-review-2023/">Kawasaki KLR650, starting at $6,899<br/>
    </a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/suzuki-v-strom-650-xt-adventure-2023/">Suzuki V-Strom 650, $9,199<br/>
    </a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/2020-ktm-790-adventureadventure-r/">KTM 790 Adventure, $10,990<br/>
    </a>
  • <a href="https://www.cycleworld.com/story/bikes/2021-bmw-f-750-gs-f-850-gs-and-f-850-gs-adventure-released/">BMW F 750 GS, starting at $9,995<br/>
    </a>
2024 Honda NX500 News and Reviews
  • <a href="https://www.cycleworld.com/motorcycle-news/honda-updates-cb500-series-for-2024/">Honda Updates CB500 Lineup<br/>
    </a>
  • <a href="https://www.cycleworld.com/bikes/honda-cb500-hornet-nx500-and-cbr500r/">NX500 First Look<br/>
    </a>
2024 Honda NX500 Claimed Specs
MSRP:$7,399
Engine:DOHC, liquid-cooled parallel twin; 4 valve/cyl.
Displacement:471cc
Bore x Stroke:67.0 x 66.8mm
Compression Ratio:10.7:1
Fuel System:PGM-FI fuel injection w/ 34mm throttle bodies
Clutch:Wet, multiplate; cable operation
Frame:Steel diamond
Front Suspension:41mm Showa SFF-BP fork; 5.2 in. travel
Rear Suspension:Pro-Link single shock, preload adjustable; 5.3 in. travel
Front Brake:2-piston calipers, 296mm discs w/ ABS
Rear Brake:1-piston caliper, 240mm disc w/ ABS
Wheels, Front/Rear:Cast aluminum; 19 in./17 in.
Tires, Front/Rear:110/80-19 / 160/60-17
Rake/Trail:27.0°/4.3 in.
Wheelbase:56.8 in.
Ground Clearance:7.1 in.
Seat Height:32.8 in.
Fuel Capacity:4.7 gal.
Wet Weight:432 lb.
Contact:powersports.honda.com
Source: 2024 Honda NX500
