2024 Honda CB300R
Started by Feed Poster, July 25, 2024, 22:01:15 PM
2024 Honda CB300R
2024 Honda CB300R in Pearl Dusk Yellow.
2024 Honda CB300R in Pearl Dusk Yellow. (Honda/)
Riders looking for an affordable, lightweight, entry-level naked sportbike should consider Honda's CB300R. This stylish machine not only looks impressive but won't break the bank with its affordable $5,149 price tag.
The CB300R is powered by a fuel-injected 286cc DOHC four-valve liquid-cooled single-cylinder engine that it shares with the CBR300R sportbike. The engine may be simple and minimalist, but it provides good performance for its size that won't intimidate newer riders.
Other highlights include full LED lighting, a new LCD dash, a solid braking system with a radial-mount four-piston Nissin caliper and standard front and rear ABS.
2024 Honda CB300R Pricing and Variants
The CB300R is available in a single model in either Matte Black Metallic or Pearl Dusk Yellow for $5,149.
2024 Honda CB300R in Matte Black Metallic.
2024 Honda CB300R in Matte Black Metallic. (Honda/)
  • 2023 <a href="https://www.cycleworld.com/story/buyers-guide/kawasaki-z400-abs-2022/">Kawasaki Z400 ABS, $5,399<br/>
    </a>
  • <a href="https://www.cycleworld.com/2018-bmw-g-310-r/">BMW G 310 R, $4,995</a> to $5,190<br/>
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/2020-yamaha-mt-03-second-ride-review/">Yamaha MT-03, $4,999<br/>
    </a>
  • <a href="https://www.cycleworld.com/story/buyers-guide/cfmoto-300nk-2022/">CFMoto 300NK, $4,199<br/>
    </a>
2024 Honda CB300R News and Reviews
  • <a href="https://www.cycleworld.com/honda-cb300r-husqvarna-vitpilen-401-ktm-390-duke-naked-bike-comparison/">Entry-level Naked Smackdown<br/>
    </a>
  • <a href="https://www.cycleworld.com/8-great-300-class-sportbikes-for-2019/">8 Great 300-Class Sportbikes<br/>
    </a>
2024 Honda CB300R Claimed Specs
MSRP:$5,149
Engine:DOHC, liquid-cooled single; 4 valves/cyl.
Displacement:286cc
Bore x Stroke:76.0 x 63.0mm
Compression Ratio:10.7:1
Fuel System:Fuel injection w/ 38mm throttle body
Clutch:Wet, multiplate
Frame:Steel trellis
Front Suspension:41mm telescopic fork; 5.1 in. travel
Rear Suspension:Pro-Link single shock, preload adjustable; 5.2 in. travel
Front Brake:4-piston, radial-mount Nissin caliper, 296mm disc w/ ABS
Rear Brake:1-piston floating caliper, 220mm disc w/ ABS
Wheels, Front/Rear:Cast aluminum; 17 in./17 in.
Tires, Front/Rear:110/70-17 / 150/60-17
Rake/Trail:24.8ยบ/3.7 in.
Wheelbase:53.2 in.
Ground Clearance:6.2 in.
Seat Height:31.6 in.
Fuel Capacity:2.6 gal.
Wet Weight:316 lb.
Contact:powersports.honda.com
Source: 2024 Honda CB300R
