2024 Honda CBR1000RR
Started by Feed Poster, July 13, 2024, 10:01:35 AM
Honda's CBR1000RR is available in one color option and with or without ABS.
Honda's CBR1000RR is available in one color option and with or without ABS. (Honda/)
At the top of Honda's sportbike food chain is CBR1000RR. With the CBR1000RR-R Fireblade SP not available in the US as a 2024 model, the standard RR is the only open-class sportbike in the lineup. The standard version was last updated in 2020. Compared to some of the competition, the CBR1000RR is pretty forgiving as a streetbike despite its racetrack capabilities.
At its heart is a 999cc flat-plane crank inline-four engine with double-overhead cams and four valves per cylinder. The engine hangs in an aluminum perimeter frame and utilizes fully adjustable Showa suspension at each end. Up front are a pair of Tokico radial-mount four-piston brake calipers with 320mm discs.
In terms of electronics, the CBR1000RR has Honda Selectable Torque Control (HSTC), which provides intervention for rear wheel slip. The rider can choose between five power curves, ten torque-control levels, three engine-braking levels, and three levels of wheelie control.
For 2024, there are two variations of the CBR1000RR with a standard $16,699 model or the $16,999 ABS-equipped model.
  • <a href="https://www.cycleworld.com/aprilia/rsv4/"><b>Aprilia RSV4</b></a>, 18,999
  • <a href="https://www.cycleworld.com/story/motorcycle-reviews/bmw-s-1000-rr-first-ride-2023/"><b>BMW S 1000 RR</b></a>, $18,295 to $25,980
  • <a href="https://www.cycleworld.com/bikes/ducati-panigale-v4-sp2-30th-anniversario-916-first-look/"><b>Ducati Panigale V4</b></a>, $24,995 to $45,995
  • <a href="https://www.cycleworld.com/kawasaki/ninja-zx-10r/"><b>Kawasaki ZX-10R</b></a>, $17,799 to $19,149
  • <a href="https://www.cycleworld.com/motorcycle-news/suzuki-gsx-r1000-update-details/"><b>Suzuki GSX-R1000R</b></a>, $18,449
  • <a href="https://www.cycleworld.com/story/buyers-guide/2021-yamaha-yzf-r1-m/"><b>Yamaha YZF-R1</b></a>, $18,399
News and Reviews
  • <a href="https://www.cycleworld.com/bikes/honda-cbr1000rr-r-sp-first-look/"><b>2024 Honda CBR1000RR-R Fireblade SP</b></a>
  • <a href="https://www.cycleworld.com/story/bikes/how-much-power-does-the-honda-cbr1000rr-r-fireblade-sp-make/"><b>How Much Power Does the Honda CBR1000RR-R Fireblade SP Make?</b></a>
  • <a href="https://www.cycleworld.com/2017-superbike-1000cc-sportbike-motorcycle-comparison-test-review/"><b>Aprilia RSV4 RR vs. Honda CBR1000RR vs. Suzuki GSX-R1000 vs. Yamaha YZF-R1 Comparison Review</b></a>
2024 Honda CBR1000RR/CBR1000RR ABS Specs
MSRP:$16,699/$16,999 (ABS)
Engine:999cc, DOHC, liquid-cooled inline-four; 4 valves/cyl.
Bore x Stroke:76.0 x 55.1mm
Compression Ratio:13.0:1
Fuel System:Programmed Dual Stage Fuel Injection (PGM-DSFI) w/ 48mm throttle bodies, throttle-by-wire
Clutch:Wet, multiplate slipper/assist
Frame:Twin-spar aluminum
Front Suspension:43mm inverted Big Piston Fork, fully adjustable; 4.7 in. travel
Rear Suspension:Unit Pro-Link monoshock, fully adjustable; 5.4 in. travel
Front Brake:Tokico radial-mount 4-piston calipers, 320mm discs (w/ ABS)
Rear Brake:2-piston floating caliper, 220mm disc
Wheels, Front/Rear:Cast aluminum; 17 in./17 in.
Tires, Front/Rear:120/70-17 / 190/50-17
Rake/Trail:23.0°/3.8 in.
Wheelbase:55.3 in.
Ground Clearance:5.0 in.
Seat Height:32.8 in.
Fuel Capacity:4.3 gal.
Wet Weight:432 lb.
Contact:powersports.honda.com
Source: 2024 Honda CBR1000RR
