2025 Suzuki GSX-R750 Preview
Started by Feed Poster, June 26, 2024, 22:17:35 PM
Suzuki keeps tradition alive and well with the announcement of its 2025 GSX-R750 sportbike, unchanged for yet another year, though available in some updated colors. The bike will start at $13,149.
There are a lot of reasons the 750 has maintained its place in the brand's lineup. For those who like a bit of nostalgia, the platform hearkens back to the original Suzuki superbike from 1986. It has remained unchanged now for going on 13 years, so lacks many of the modern electronic upgrades that have become standard on other models, coming with only the Suzuki Drive Mode Selector system and an electronically controlled steering damper. A boon to those who prefer a more analog experience on the road or track.
The 2025 Suzuki GSX-R750 in Pearl Brilliant White and Metallic Matte Stellar Blue.
The 2025 Suzuki GSX-R750 in Pearl Brilliant White and Metallic Matte Stellar Blue. (Suzuki/)
It provides 600-level agility with an engine that feels like a "race-prepped 600 with a beefier bottom-end," according to our tester during our last ride on the platform. It's proven its chops in the MotoAmerica Supersport class and has become known as a remarkably comfortable and easy-to-ride motorcycle for street riders.
For a little refresher, the GSX-R750 is powered by a 750cc inline-four that we've found is capable of putting down around 121.5 hp at the rear wheel. It utilizes a 600-style chassis with a Showa Big Piston Front Fork and a Showa shock, along with Brembo Monoblock calipers at the front. It has a back-torque-limiting clutch, a built-in lap timer and programmable shift light, and a cockpit that eagerly welcomes a wide variety of riders.
2025 Suzuki GSX-R750 in Solid Iron Gray and Glass Sparkle Black.
2025 Suzuki GSX-R750 in Solid Iron Gray and Glass Sparkle Black. (Suzuki/)
Beyond that, there's not a whole lot to say. The GSX-R750 will be available in Pearl Brilliant White and Metallic Matte Stellar Blue or a combination of Solid Iron Gray and Glass Sparkle Black. A GSX-R750Z edition will also be available, coming in Suzuki's classic Pearl Brilliant White and Metallic Triton Blue.
2025 Suzuki GSX-R750Z in the classic Pearl Brilliant White and Metallic Triton Blue color.
2025 Suzuki GSX-R750Z in the classic Pearl Brilliant White and Metallic Triton Blue color. (Suzuki/)
2025 Suzuki GSX-R750 Technical Specifications and Price
Price:$13,149
Engine:750cc, DOHC, liquid-cooled inline-4
Bore x Stroke:70.0 x 48.7mm
Compression Ratio:12.5:1
Fuel Delivery:Fuel injection SDTV
Clutch:Wet, multiplate
Transmission/Final Drive:6-speed constant mesh/chain
Frame:Twin-spar aluminum
Front Suspension:Showa Big Piston Fork, spring preload, compression and rebound damping adjustable; 4.7 in. travel
Rear Suspension:Showa shock, spring preload, compression, and rebound damping adjustable; 5.1 in. travel
Front Brake:Brembo Monoblock 4-piston calipers, 310mm discs
Rear Brake:Nissin 1-piston caliper 220mm disc
Wheels, Front/Rear:3-spoke cast aluminum; 17 in. / 17 in.
Tires, Front/Rear:120/70-17 / 180/55-17
Rake/Trail:N/A
Wheelbase:54.7 in.
Seat Height:31.9 in.
Fuel Capacity:4.5 gal.
Claimed Curb Weight:419 lb.
Available:TBD
Contact:suzukicycles.com
Source: 2025 Suzuki GSX-R750 Preview
