Tighten rear turn signal
Started by moto, October 05, 2018, 04:50:01 AM
moto
Quote from: drifter-paul on October 05, 2018, 05:34:27 AM
Moto,
Use your thumbnails or a wooden paddle pop stick to ease the semi-hemisphere plastic cap off the housing stalk, and along the wire towards the brake light / licence plate housing. You will then see the 14mm nut. It is rubber mounted. The plastic cap is a clip back on fit.
Yes, I knew it! Thanks Paul!
Let the good times roll
drifter-paul
#2
Moto,
moto
Hi
where I can tighten my Drifter rear turn signal, it is now little slacky. I cannot find any bolt.
Is bolt inside turn signal rod?
