1500 ign work
Started by drifterbob, April 01, 2011, 17:08:01 PM
drifterbob
Findaly got some hi temp wire and completed to job, works like a champ and no more breaking my back to work the ign.  I left the stock ign in place for back up.  Thanks again guys for the info.   Drifter Bob
drifterbob
Thanks Chief and Troll, that should get me going in the right direction.  I'll post how it turns out later and thanks again :)
Quote from: drifterbob on April 01, 2011, 17:08:01 PM
Hi all, need some info on ign work on my 1500 Drifte (2002).   I have a Thunder (Harley type) ign sw. I've located on the left side (tool) cover. I want to leave the old sw intact and splice in the new one for ign only (no park lite)  The info from Thunder shows puting a 100 ohm resistor in line with one ign wire (there are 2 ign wires), I've had the old (stock) sw apart and don't see a resistor there.  Do I need the resistor?  My thoughts were splicing into the 2 ign wires and Batt wire, then tying the 2 ign wire together on the new sw post.  If any ones been there I would love to hear from you.      Thanks, Drifter Bob
Yes, its required.  As Troll indicates it is necessary.  its 100ohm, 1/2 watt - ensure you put it in the correct way... some folks have installed backwards...
Go over to the web site and click on Accessories or Mods/Tips - once there click HOME and then at the top type ignition into the search box... you will come up with a page of info on this mod (and various accessories as well). There are 3-4 mods listed. This is one of them...
http://www.vulcandrifterriders.com/jobearIgnition.html
  This is the thing that cost me big bucks last season, and a fuel pump I didn't need.   The 100ohm resistor is built into the stock ign. to prevent theft by just crossing the wires. The ECM needs to see a correct voltage on the circuit, or it will not turn on the fuel pump. I still have my thunder ign switch, it was mounted in a nice chrome upper handlebar bracket, on the risers... mine is sitting on a shelf in the garage.  It uses the H-D riser pattern......ya want it?
drifterbob
