pressure sensor
Started by rimshot, March 28, 2017, 21:48:25 PM
There are two identical sensors under the tank. One is Baro, and the other is MAP. Baro sensor has it's vacuum hose fitting open to the air (to measure BAROmetric pressure) and MAP has it's fitting connected to the manifold to measure vacuum (manifold absolute pressure). The sensors are the same part number, so the wiring color code will tell you which one is which...
Trall
Idk.  You might check Partzilla.   You can pull up the parts you're looking on their diagram will show all the related parts and there placement on the bike for that area.
rimshot
hi when i had a hypercharger installed all the lines and hoses were pulled off and never replaced. the only thing im trying to work out is the hoses from the pressure sensor / air water switch relay sensor ? where should it connect to? thanks
