dual to solo saddle
Started by TINTINBOF, March 19, 2014, 18:38:07 PM
TINTINBOF
I thought my dual seat was a bit shaky  only the small back bolt holding the seat on  :o   Thanks again the diagram explained it all
Yeah, you can't buy them, apparently never a separate component
TINTINBOF
Thanks for your quick reply  ;D looking at the diagram of the solo saddle i am missing the 2 triangular brackets that are attached to it. Thanks again i will make a couple
If it's a factory dual seat, the two brackets are the same ones that are on the solo seat...all you need is a 10mm socket wrench.
TINTINBOF
Hi i have a 2001 1500 with a dual seat, i have just purchased a solo seat 53001-1991-ma . I have put the solo seat on but i appear to need some brackets to hold the new solo seat down. Has anyone got the part number that i need to do this or has member come across this problem before maybe making his own brackets. Any advice would be appreciated. Thanks Gents
