What is it called
Started by CDNRatMan, August 22, 2013, 22:03:04 PM
  ok that settles it winter project #WTP 56 , order one for a Vulcan 900 ....same tire size .....and we can make it fit......
my list is getting longer once more for the projects......
David Baker
CDNRatman... Heritage Hubcap... I bought one at a local cycle parts shop ($15.00) took a dremel to it to open the hole and epoxied it to the speedo... Easy Weezie... Nifty Thrifty!
  Yes but if it is good enough for you then I can make it work too.....
Found lots for a Vulcan 900, now to see if I can make one work for me.....
more chrome to keep clean...but it covers the plain spoke hub. Had one of these on each of my wire wheel H-Ds...
  Thank you Sir Troll I'll keep looking. I think it just adds that something special to the front end.
That's an F&S accessory cover. Found it on eBay couple of years ago. It's for a classic with speedo drive, so I had to make my own spacer to mount it...no big deal. The same one should fit yours with no modification, since it has a hole for the speedo cable and a large diameter center with 3 set screws...er...grub screws...
griz01
1999 Drifter 1500
 oh .....never mind....it will just come back and bite my a$$.....
Thanks Nanook, at least your polite.....
That's the front wheel you have circled, if I'm not mistaken Ratman...    8)
I believe your Sunbeam Red Drifter already has one.... ;D
  Never seen one yet on a Drifter but thought it might look good on a dark bike, just that hint of chrome, but cannot seem to find one on line because I can not find a name for it. Yes I tired but came up empty I have the part circled in yellow. I tried a number of words but nothing hit for me. so any help ..Thanks.
