breaking with tradition
Started by Troll, July 16, 2012, 08:17:43 AM
Watch for cupping on that front tire. I raised the psi on the front because of severe cupping. I'm interested in seeing how this works out for you.
Ok, then. I said I'd keep you up to date about the Michelins, and so I am...I have 3,300 miles on the set, now, and just measured the thread depth.  The front started with 5/32, the rear with 9/32....I'm running 28 psi in the front (factory pressure recommendation) and 36 psi in the rear....after 3,300 miles the front is 5/32, and the rear is 8/32....I don't expect this to remain constant, but I'm pretty happy with them, so far. I took a little 75 mile ride yesterday to test my new (stock, almost) exhaust for effect on fuel mileage. I went over a route I've been over many times before. It includes a steel deck bridge at Lansing, Ia which is a little over a 1/4 mile of steel....not too much squirm and wiggle...probably the same as the Metzelers..and just in case you wondered...1.5 gal for 75 miles.......
Ok...so now I can tell you a little more about the Michelins and their projected wear rates/dry and wet handling. I have 2,000 miles on them now, and the front shows no measurable wear, the rear has worn about 3/4 of 1/32. I got to ride in 160 miles of heavy rain and thunderstorms yesterday, and the tires didn't disappoint. I don't think they were any less stable than the Metzelers, and they seemed to have the same wet weather traction as the ME 880s. I don't push hard in the rain, so I was running mostly 55-60 on county highways. So far, so good. As a side note, I turned over 71,000 on my Drifter, yesterday. Almost a year to the day I turned 59,000. Got a picture....I know you guys love pictures...me too. Took a shot of the thunderstorm I was riding in, too. We've been under drought conditions for months, so I wanted to share something nobody's seen around here since May...
The front one is on, now. It's about 1/4" smaller in diameter than the Metzeler, but the same size as the stock Bridgestone. The tread depth is 5/32. Michelin recommends the factory pressure, so I have it set at 28 psi.  So far, they are very smooth and quiet. I had the bike up to about 90 this morning and it's quite stable, no head shake in corners.  I haven't noticed any ground clearance problems, but I haven't practiced any ERC exercises, either...only time will tell. If these tires perform as Michelin says they will...if only I could believe it......
I put the rear one on today. The picture shows the difference in width between the correct size tire (the Michelin) and the tire I have been running. I measured the ground clearance before I changed the tire and after...there is a 1/2" change. The bike is now lower, so I will have to get used to the new limit of lean, all over again. I'll be checking and calibrating the speedo healer tomorrow, as well as running in the new tire, experimenting with handling differences, etc. The tread depth is 9/32" and it's inflated to 34 psi...have to start somewhere.  Just in case you noticed... I was a flat rate auto tech for over 40 years... you don't remove anything that you don't have to.  After you take off the fender, the bags and rack are something that you can easily work around...The new front tire will go on Wednesday....
OK...I put 400 miles on the bike yesterday, doing a class at Road America, and today, I pulled off the rear wheel. I won a $75 gift certificate at the local Kaw dealer, so I'm taking the wheel over there tomorrow to have them mount the Michelin, with a new tube, for free. I only have the ability to raise one end at a time, so I figured I'd get the biggest PITA done first...The Metzeler still has 5/32 tread left after almost 15,000 miles, but it was really getting feathered on the tread edge, and you could hear it sing when you banked into a turn. I'll get the front done this week, too, but first things first...I have a local class coming up this weekend, so I'll be putting on about 250 miles going to that, plus whatever I ride during the week. I suspect I'll have around 500 on by next Sunday, so i should be able to give some kind of report about the frog skins...
The speedo healer, with an initial set up gave me 64.3 mph actual @65 indicated...not too bad. I think I can live with that...however, the odometer is off, now. When I put on the new tires, I'll have to do it all over, but it's pretty easy to set up, and for now, it actually works as advertised!
Sooo, the Michelins arrived today. Both made within the last 3 months, both come from Thailand......hmmmm. I bought a speedo healer with the correct adapter cable from the only distributor in the country, for $116. That little gem took all of about 15 mins. to install. I'm going to check it out tomorrow. This morning, I had to make a computer house call, so I used my big boy handy dandy MSF stop watch to check my speed on the interstate. Speedo read 72, the watch said 69.9. Programmed in a -2.9 correction factor in the speedo healer... testing it tomorrow. The difference in tire diameter between the sizes is the reason for the calibrator box. The stock, 150/80-16 is 26.5" in diameter, the tire I've been running, 160/80-16 is 27.4", and the Michelin is 26.06"... don't want people on mopeds passing me.
   Well, I didn't wait for any feedback. I had a deal cooking and it was time sensitive...so I pulled the trigger. $130 for the rear, $116 for the front. I talked to a guy who's been the business for almost ever, and he couldn't say enough nice things about them. Says he can't keep them in stock, been putting on 2 or 3 sets a week.  On line reviews make them sound wonderful, but you know how that goes...I decided to order a speedo healer since I'm going to be running the 150/80-16 instead of the 160/80 that I have had on. Hopefully I can tweak the speedo close enough to make me happy. I'm in no rush, the Metzelers are still quite usable. I'll probably be putting them on in August, when the bike has about 70,000 on it.
aclone
I just put Metezler's  on my 1500 they are pricey.  Had the dunlop's  got almost 15,000  out of the back and 18000 out of the front.  The Metz handle better than the dunlop's just hope they last as long. Very intrested in hearing if you like the michellin it's always good to have another choice. Good luck in your search.
When we bought our Aurora the ride wasn't what it should have been for that particular "advanced" feature automobile. The dealer replaced the stock tires with Michelin ... they absolutely lived up to the hype in this instance. We continued to use them on that vehicle until we gave it to our son... who still uses that brand.
Strangely... I use dunlop on the goldwing - have replaced them twice. They are very good on that bike. On the Drifter, dunlop sucked... have used several other brands but stuck with Metz... That said, Avon and Continental have new offerings which look interesting. The August issue of Rider has an article on bike tires.
  My tradition, at least. I've been running Metzelers since about 1980 or so, but now I'm considering replacing the tires on my 1500 with the new Michelin Commander II.  I've never been a Michelin fan, when it comes to car tires. I believe they have an undeserved reputation  for quality, and their wet weather traction has never been as good as it could be...that said, I've been reading some reviews for the Commander II.  So far, it seems that they may have a  winner here, but I was wondering if anyone else might have some thoughts about it...
