Where can I get custom Stainless Speedo cable for 800
Started by rbart, May 16, 2010, 18:25:24 PM
Yeah the Nomad cable is a bit longer which apparently resolves the problem... that was originally intended for the 1500 (99/00) but I suppose its the same for the 800.
rbart
I have gone through 3 custom cables from Barret so far, it seems that the paddle end is pushing up into the steel housing causing it to bind. I heard that I should be looking at a Nomad cable instead, need your help with this one guys.
Ron
