oil Change
Started by michaelh42, July 21, 2011, 08:24:06 AM
griz01
I have used the Mobil 1 V Twin 20-50 oil since I purchased my drifter. I like it, really seems to quiet the motor. It is not supposed to be the same as the Auto version. Watch out for Friction Modifiers, that is what messes up the wet clutches it our bikes.
Filter is at the rear of the motor, just ahead of the rear wheel swing arm. If your "converter" has been removed it is very easily reached from underneath.
I use the Bosch 3300 filter on mine. It has metal interior valves and 'advanced filter media', also Made in USA; if you care about such things.
On the oil change, be sure to clean the screen, located behind the larger plug on the oil pan.
1999 Drifter 1500
michaelh42
I am getting ready to do my first oil change on my Drifter. any suggestions on oil? I saw Mobil 1 V-Twin but isn't that the same as regular Mobil 1? just different packaging? Also where is the filter???? and what kind should I get?
Thanks for the help
