Fairly large gas leak. Thoughts?
Started by dkeshish, November 27, 2015, 01:57:52 AM
 Also as an after thought check the picture for later after you get the oil leak figured out. Part number 92066-1434 for the frame plug.
  Ok there is a single 8 mm (I think) bolt that holds that chrome piece on and you can remove it because behind it is the front sprocket of the chain, and you will see better what is happening, example is that might just be excess lube from the chain, if you recently lubed the chain. So take it off and you can clean up in that area and then see actually were it is leaking from.
Once you have it off it will be clear were it is leaking from, and then you have the joy of getting it back on with that little rubber gasket and then you finesse it back into place replace the bolt and you are done.
Be a good time to clean around the front sprocket.
dkeshish
Quote from: dkeshish on November 27, 2015, 01:57:52 AM
So guys need a little help,advice,thoughts. I rode my bike a few days ago parked it in the garage. Next day I noticed some drops of oil right below the window viewer of how much oil u have. I thought its nothing and cleaned up the bike to see if it happens again. Havent turned it on or anything past 2 days and now I notice more oil on the ground. From the pics it looks like its from the transmission cover. Anyone have this issue? When I changed my oil I didn't use synthetic oil...
close up
dkeshish
So guys need a little help,advice,thoughts. I rode my bike a few days ago parked it in the garage. Next day I noticed some drops of oil right below the window viewer of how much oil u have. I thought its nothing and cleaned up the bike to see if it happens again. Havent turned it on or anything past 2 days and now I notice more oil on the ground. From the pics it looks like its from the transmission cover. Anyone have this issue? When I changed my oil I didn't use synthetic oil... I changed my rear tire as well
